I did not find any information about this issue using search-function.
Sorry, if this has already been discussed anywhere...
Is it possible to choose colorspace (from exif data) as a (custom-) Thumbnail Label ? How ?
If not yet, any plans to implement this? (Should be easy, not?)
Thanks, Arno
Exif [colorSpace] -> Thumbnail Label
- Forum Librarian
Arno
Re: Exif [colorSpace] -> Thumbnail Label
Thanks for quick response, XnTriq.
Maybe I was a bit unclear....
Well, I did not think of an icon, but text-labels (infos) under the thumbs
(which you can select under Options>Thumbnails>Thumbnail Label).
Just to give an idea of what I would like to see:
Well, seems that I can't post images ... (why?)
Anyway -, so let me explain.
E.g.: Working with different cameras, I sometimes use sRGB, sometimes use Adobe RGB ColorSpace and convert later with Photoshop to sRGB.
I would like to see this (exif-) Information listed as (text-)label under the thumbs (as I can list exposure data or scene Type e.g.)
There are a lot of exif-tags to choose as a label, but unfortunately I miss Colorspace ....
Arno
Arno
