As many of you probably know, there is a RIOT (Radical Image Optimization Tool) addon for XnView created by the XnView author - that is the addon not RIOT itself.
For users that don't know yet about RIOT, this is a free image optimization tool, very handy for reducing the image filesize.
In the past RIOT could be plugged into XnView only manually by copying the required files.
But now the RIOT addon for XnView comes as an easy to use installer.
The installation wizard will locate any supported host applications like XnView, IrfanView or GIMP and and automatically copy files to the proper location. No more troubles with copying FreeImage.dll and RIot.dll in the correct location !
The installer can be downloaded from the RIOT website:
http://luci.criosweb.ro/riot/download/
RIOT Plugin Installer
luciansabo
lian
Re: RIOT Plugin Installer
Hello, I cannot find the Riot menu after installing the plugin. Where should I search ?
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
lian
You are right ! I thought I used the 64 bits version and it’s the 32 bits. Sorry for being quite dumb.
- Forum Librarian
lian
What happens if I uninstall 32 bits version after installing 64 bits version ?
- Forum Librarian
Hello lian
Both the 32- (Riot-plugin-x86.exe) and 64-bit (Riot-plugin-x64.exe) version of RIOT come with these files:lian wrote: Mon Jan 16, 2023 9:20 pmWhat happens if I uninstall 32 bits version after installing 64 bits version ?
- FreeImage.dll
- Riot.dll
- riot.exe
- uninstall-plugin.exe
- changelog.txt
- FIPL.txt
- license.txt
- Riot.xnp
lian
Thanks but I was not precise enough. I was speaking about XnViewMP. Can I uninstall v.32 bits if 64 bits is already installed or do I need to uninstall both versions before reinsalling XnViewMP 64 bits ?
yes i think that you can remove 32bits version without problemlian wrote: Tue Jan 17, 2023 12:54 pm Thanks but I was not precise enough. I was speaking about XnViewMP. Can I uninstall v.32 bits if 64 bits is already installed or do I need to uninstall both versions before reinsalling XnViewMP 64 bits ?
lian
I tried, it seems to work. Thanks.xnview wrote: Tue Jan 17, 2023 1:11 pmyes i think that you can remove 32bits version without problemlian wrote: Tue Jan 17, 2023 12:54 pm Thanks but I was not precise enough. I was speaking about XnViewMP. Can I uninstall v.32 bits if 64 bits is already installed or do I need to uninstall both versions before reinsalling XnViewMP 64 bits ?
