Hello everyone, This is probably a simple question but my software skills are not that great.
How do I convert old mix files to jpg so that I can open and edit them with my current program?
Thanks, Jim
old mix files
Re: old mix files
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=80332#p80332]Old PhotoWorks floppy disk[/url]) wrote:
.MIX = MS Picture It! & MS PhotoDraw & MS Image Composer
Wikipedia (Microsoft PhotoDraw » [url=http://en.wikipedia.org/wiki/Microsoft_PhotoDraw#Use_of_the_.MIX_file_format]Use of the .MIX file format[/url]) wrote:PhotoDraw's native file format is “.mix”, a proprietary format developed by Microsoft. Only PhotoDraw can save and load its MIX files and retain the full ability to modify those files.Forum references:
- Microsoft Answers: Is Picture It! Premium 10 compatible with Windows 7?
- About.com: Graphics Software » Whatever Happened To... Image Composer & PhotoDraw 2000
