Trying to convert a MIX to a jpg.
ChuanChe
Post by ChuanChe »
When I try converting it, program says that this is not an image. I'm working with a couple of files that were made with PhotoDraw and Picture it! long time ago.
How can i solve this problem?
Thank you.
Moderator & Librarian
Re: Trying to convert a MIX to a jpg.
Unfortunately, MIX is a closed proprietary format. XnView can only read embedded thumbnails from such files and relies on an I/O plug-in (Xcompound.dll) to do so.
In order to install the plug-in, you have to download cpnd.zip (3D Studio Max + Picture It! + Image Composer) and extract the contents of the archive into the Plugins subdirectory of your XnView installation.
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=80332#p80332]Old PhotoWorks floppy disk[/url]) wrote:
.MIX = MS Picture It! & MS PhotoDraw & MS Image Composer
Wikipedia (Microsoft PhotoDraw » [url=http://en.wikipedia.org/wiki/Microsoft_PhotoDraw#Use_of_the_.MIX_file_format]Use of the .MIX file format[/url]) wrote:PhotoDraw's native file format is “.mix”, a proprietary format developed by Microsoft. Only PhotoDraw can save and load its MIX files and retain the full ability to modify those files.
Forum references:
