Next/previous file buttons
Hans L
Post by Hans L »
What can I do to get the Next/previous file buttons to show files in the order they occur in Windows Explorer (alphabetical, for instance)?
Thanks,
Hans Leander
Re: Next/previous file buttons
you need to choose sort method in browser
Hans L
Post by Hans L »
If you mean XnView > Tools > Options > Browser, I cannot find anything there about sorting. My Windows Explorer (actually, a replacement, DOpus; extremely good) is sorted alphabetically (all jpg files). Kindly advise.
Hans L
Hans L
Post by Hans L »
Hello again:
I now realize that XnView sort differently than DOpus. Here is show XnView sorts:
which, I must say, is somewhat strange.
Regards,
Hans L
Have you looked at the browser View > Sort By options Name and Name (numeric) ?
Hans L
Post by Hans L »
cday, had missed that , because it shows up only if you open XnView directly. And, in the list that shows up there, it makes no difference if I have Name or Name (numeric): the order in that display is the way I want it, namely
However, when I open XnView by clicking on a jpg file, first, under View, there is no Sort, and, second, whether I have set Sort to Name or Name (numeric), it sorts
However, I get correct sorting if I have
(underscore instead of hyphen).
Regards,
Hans L
Karl02
Post by Karl02 »
^ I can confirm this wrong sort order when starting XnView directly in view mode.
Tested with XnView v2.33 (2015-06-18) on Windows 7 64 bit SP1.
-- Karl
Hans L
Post by Hans L »
Thanks for testing and posting, Karl. I'm sure Pierre (developer?) reads this.
Regards,
Hans L
ok, i'll check
Hans L
Post by Hans L »
Thanks, Pierre.
Hans L
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=123689#p123689]Replacement for Windows Photo Viewer[/url]) wrote:There's Name and Name (numeric) in View » Sort By.
In addition to that, you can change the behavior by editing xnview.ini:
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Browser]Browser[/url]) wrote:
OldSortMethod
  • When disabled, XnView will use the same sort order as Explorer on Windows XP and later: File names are sorted based on numerical value (3 < 22 < 111).
    When enabled, XnView will use the same sort order as Explorer on Windows 2000 and earlier: File names are sorted literally (111 < 22 < 3).
    Value: Boolean (1/0), disabled by default
    Added in v2.25
Related topic: XN 2.23 - "View Thumbnails Panel" changed order of files
Hans L
Post by Hans L »
Thanks./Hans L
