B1: Filter > Deskew or Image > Deskew
The new function "Deskew" is used for de-skewing scanned grey-scale or black and white images. I wonder whether the main menu item "Filter > Deskew" is the right place. I would expect it in "Image > Deskew", where other menu items like "Rotate" are located.
XnView 1.82 <x>
and worse:::
• I agree, and besides, I guess that a more explicit term might be found : for instance, this is untranslatable correctly in French, it needs more explanations…
- In addition, "Deskew" is nowhere to be found in the dictionaries…
:mrgreen: G.
Re: B1: [?] Filter > Deskew or Image > Deskew
helmut wrote:The new function "Deskew" is used for de-skewing scanned grey-scale or black and white images. I wonder whether the main menu item "Filter > Deskew" is the right place. I would expect it in "Image > Deskew", where other menu items like "Rotate" are located.
Ok
Re: and worse:::
Perhaps it's a bit clearer if "De-Skew" is used, analogue to "De-Interlace". What do English native speakers think about "De-Skew"?
Xyzzy
Post by Xyzzy »
Googlefight says:
112.000 for deskew, 137.000 for de-skew.
We've got a winner.
Btw, I cannot make it work. I select rectangle with top margin of skewed document, use Deskew and nothing happens...?
X.
Xyzzy wrote:Googlefight says:
We've got a winner.
Good idea to use Googlefight. It will be "De-Skew", then.
Xyzzy wrote:Btw, I cannot make it work. I select rectangle with top margin of skewed document, use Deskew and nothing happens...?
If De-Skew can find a skewed horizontal line, it will work. Perhaps such a horizontal line was not recognized in your image. Reason might be to faint contrast (just guessing).
Perhaps De-Skew can be made a bit more verbose and report an error message if de-skewing could not be applied for some reason.
Some possible user messages:
- horizontal line was not recognized
- horizontal line was recognized, but is horizontal, already.
Xyzzy
Post by Xyzzy »
Supported :!:
Edit: and still I cannot make it perform anything.
X.
In Beta 3 we have "De-Skew", which is good. But there are still no additional informational messages (see my previous post).
:arrow: Group "Confirmed/Reproduced"
In RC1 there is still no message box when De-Skew cannot de-skew when all lines are horizontal already or the selected area contains no contures to do de-skewing at all.
Still not fixed.
helmut wrote:In RC1 there is still no message box when De-Skew cannot de-skew when all lines are horizontal already or the selected area contains no contures to do de-skewing at all.
Still not fixed.
I can't know when there is no horizontal line...
Ty
Deskew
Post by Ty »
I also have had trouble deskewing. In my case I'm trying to straighten a gray picture that is slightly tilted but which has no horizontal lines. So I can't use deskew.
I don't know if it would be worth the trouble for P to program, but I've seen a nice solution to this problem. When you click on "deskew", a little message pops up and says "draw a line that SHOULD be horizontal across the image," and then the cursor goes into a mode that allows the user to draw a line along some surface or edge. On <enter>, the program rotates the image so that line (which of course disappears) is now perfectly horizontal.
I find the "adjust by degrees" of the rotate function rather tedious, slow, imprecise and not verifiable.
Re: Deskew
Ty wrote:I also have had trouble deskewing. In my case I'm trying to straighten a gray picture that is slightly tilted but which has no horizontal lines. So I can't use deskew.
I guess "De-Skew" can't help you with that image.
Ty wrote:I don't know if it would be worth the trouble for P to program, but I've seen a nice solution to this problem. When you click on "deskew", a little message pops up and says "draw a line that SHOULD be horizontal across the image," and then the cursor goes into a mode that allows the user to draw a line along some surface or edge. On <enter>, the program rotates the image so that line (which of course disappears) is now perfectly horizontal.
Good suggestions and comment. Suggestion Rotation based on the horizon line +auto-crop option is very related.
