Help file not up to date
Re: Help file not up to date
Olivier_G wrote:
helmut wrote:So if someone knows of a free or cheap solution which allows for writing up structured help documents easily, please write here.
Just found the freeware HelpNDoc in those lists: 1, 2
Would it fit the bill? (I don't have enough experience in html, help files to evaluate it... :( )
(Screenshot)
Softpedia ([url=http://www.softpedia.com/reviews/windows/HelpNDoc-Review-29422.shtml]HelpNDoc 1.9 Review[/url]) wrote:The Truth
In the past I have seen some really big programs built with the only purpose to create help files, but I can't remember even a single one now. HelpNDoc is an application to remember, easy to use, fast and free for personal use. If you want to help other people, help yourselves...get HelpNDoc!
IBE Software ([url=http://www.ibe-software.com/products/software/helpndoc/new.php]What's new in HelpNDoc[/url]) wrote:Version 1.10 - May 28th, 2007
  • Better Windows Vista compatibility
  • Fixed HelpNDoc's help file display exception under Windows Vista
  • Fix for the & character in project title when exporting to CHM
  • Right Alt + A was selecting all the topic's text and caused problems with certain keyboard layouts
  • Lower memory usage for GIF images
  • Better table support
  • Better HTML Import / Export
  • Topic Editor enhancements and bug fixes
