File size became horrible after "Create Multipage"
Post by Guest »
Hi all,
I liked the "create multipage" feature very much. But the filesize after convert seems unacceptable. I tried to merge two jpg below 150KB to a tiff and became 5MB. How can I compress the size? Please advise. Thanks a lot.
Re: File size became horrible after "Create Multipage&q
Guest wrote:I liked the "create multipage" feature very much. But the filesize after convert seems unacceptable. I tried to merge two jpg below 150KB to a tiff and became 5MB. How can I compress the size? Please advise. Thanks a lot.
Use Compression
Cannot found the compress function
Post by Guest »
Hi Pierre
I cannot found the compress function in the menu, can you kindly tell me more details for this. Thanks a lot.
Re: Cannot found the compress function
Guest wrote:I cannot found the compress function in the menu, can you kindly tell me more details for this. Thanks a lot.
Use -c 1 or -c 2.
use -c 1 or - c 2???
Post by Guest »
Hi Pierre,
Sorry, are we talking the same language? I'm using Xnview for Windows XP. Where is the -c 1 or - c 2? Can you please guide me from the menu bar such as File or Tools? Thanks anyway.
Re: use -c 1 or - c 2???
Guest wrote:Hi Pierre,
But you are in the NConvert group :-) In XnView, use options/Write/Tiff
guest
Thank you but ...
Post by guest »
Hi Pierre,
Thanks. I saw two option under TIFF:
Colour options: None, Packbits, LZW, LZW+Predict., ZIP, JPEG
Binary options: None, Packbits, LZW, ZIP, CCITT G3, CCITT G3-2D, CCITT G4
But can't see "c 1" or "c 2", please help if possible. Thanks a lot.
Re: Thank you but ...
guest wrote:Hi Pierre,
Here is, use LZW for example.
Working much better
Post by Guest »
Dear Pierre,
It works much better now. I tried several combination with 2 jpeg in 1xxKB, the result of create multipage is around 1.3MB. Do you have any idea to compress the TIFF in the ideal size? Or, just give me some hints about the compression parameter such as LZW ...
BTW, thank you very much.
Re: Working much better
Guest wrote:Dear Pierre,
If original file are jpeg, use jpeg compression for TIFF
guest
Thank you
Post by guest »
Hi Pierre,
You're really helpful. Thank you very much.
