Export again
Dreamer
Export again
Post by Dreamer »
Keyboard shortcut is still missing.
Also when Tab is pressed, it should switch to quality options (select number to be able to type quality or change it by arrows) IMO, to quick set format, quality and save.
XnView 1.90 <x>
Dreamer
Re: Export again
Dreamer wrote:Keyboard shortcut is still missing.
Shortcut for export?
You menas not go to buttons Cancel/Save, right?
Dreamer
Re: Export again
Post by Dreamer »
Yes, some users will use it instead of save as quite often I think...
Not really, just go to options, quality first.
This is what I'd like to do - with keyboard:
- press shortcut to open export dialog
- choose format by arrows
- switch to quality options by Tab (or/and down arrow, if possible, it would be even better - currently it works, it switches to [Save])
- choose quality by arrows or type number
- press Enter twice to save it
Dreamer
Re: Export again
Do you have a shortcut for it? :-)
Dreamer
Post by Dreamer »
Of course. :)
Ctrl+Alt+S, but also Ctrl+E would be nice, but it's reserved, so Ctrl+Alt+S would be logical and intuitive enough I think - Ctrl+Shift+S is to "Save as", this will show "Save as" dialog later too.
Dreamer
Olivier_G
Post by Olivier_G »
-> Ctrl+Alt+S opens Export dialog in Beta 5.
Dreamer wrote:This is what I'd like to do - with keyboard:
Not implemented in Beta 5.
That would be nice indeed (Focus on Format Tabs and left/right arrows to move between them, down arrow to switch to tab content (quality first, on top), up arrow to focus back to Format tabs.
Olivier
Dreamer
Post by Dreamer »
Focus is on format at the beginning in beta 5, but:
- after <Tab> it's on Cancel button
- after change to other format by <right> format is changed once to GIF, but then focus is lost, so format cannot be changed by arrows
Dreamer
