Change sorting order for filenames
qwerty
Post by qwerty »
I really enjoy working with XNView. It's an exellent app. However, I have 1 remark about it.
Obviously, XNView uses "intuitive filename sorting", as WinXP and 2003 use by default. This means that a file called "File 5" comes before "File 10" because 5 comes before 10.
However, in WinXP/2003 you can change the filename sorting to "literal sorting" (the default of Win2k and earlier), which means that "File 10" comes before "File 5" because 1 comes before 5 (which I personalle find far more logical).
I tried to find an option to change this in XNView but I couldn't find it. I think it would be most logical that XNView follows the Windows setting in this respect. However, it doesn't.
Does somebody knows a way to solve this?
Re: Change sorting order for filenames
qwerty wrote:I really enjoy working with XNView. It's an exellent app. However, I have 1 remark about it.
Use sort by name (numeric)
qwerty
Post by qwerty »
Unfortunately, I cannot find where to change this option.
Can I set this in a generic way (for the whole program) or can it only be done for a specific task/project?
The point for me is that XnView doesn't follow the order in which the files are shown in explorer.
qwerty wrote:Unfortunately, I cannot find where to change this option.
In the browser, menu View/Arrange by
qwerty
Post by qwerty »
Thanks very much!
So setting it there works also for other parts of the program!
