How to print a few fotos on one sheet?
Volodya
Post by Volodya »
For example: i try to print 4 fotos on one sheet using all sheet space. How to do that?
Re: How to print a few fotos on one sheet?
Volodya wrote:For example: i try to print 4 fotos on one sheet using all sheet space. How to do that?
You can't directly, you must create a contact sheet, then print it
Volodya
Post by Volodya »
Ok, i'll try to, thanx for yr replay
Volodya
Post by Volodya »
But, can г tell me how much pixels in A4 sheet?
Volodya wrote:But, can г tell me how much pixels in A4 sheet?
If you want a 72 dpi A4, use 595x842
Volodya
Post by Volodya »
and if i want 300 dpi or 600?
is there any difference if my fotos different dpi? how to count pixels in this case?
Volodya wrote:and if i want 300 dpi or 600?
in 300 dpi => 2500x3510
in 600 dpi => 5000x7020
No
Volodya et al,
One inch is 2.54 cm.
DIN A4 page is: 21.0 x 29.7cm, which is 8.268 x 11.693 inch.
Now it's easy to calculate the number of pixels you need, e.g. for 300 dpi:
Width: 300 dpi x 8.268 inch = 2480 pixel
Height: 300 dpi x 11.693 inch = 3508 pixel
