convert bmp into smaller ps
Post by Guest »
Hello
I try to conovert my barcode.bmp into a .ps-file in a batchfile.
the command:
works :D
now I need the ps CR/LF instead of CR and I need the width and height ca. 50% smaller. I tried:
  • -ratio
    -rtype linear
    -size 20000
    -resize100 200
but I had no success. :(
I use NConvert 4.22. Do you know something?
Re: convert bmp into smaller ps
Anonymous wrote:I try to conovert my barcode.bmp into a .ps-file in a batchfile.
the command:
works :D
  • -ratio
    -rtype linear
    -size 20000
    -resize100 200
Currently the ouput support for ps is very simple.
