PGB format
pizza
PGB format
Post by pizza »
I have the following question. First of all what is PGB? Is it a greyscale image?
As far as I understand pixels there are coded with intensivity of black (or white?) 0-255.
How can I retrieve those numbers from the image file, i.e. how can I obtain a txt file with mere numbers (codes of the pixels)? Can I do this with XnView?
I would greately appreciate your reply!
:D
pizza
Post by pizza »
Sorry! not PGB, but PGM format!
Lostclown
Post by Lostclown »
You are right that PGM is a grayscale format.
A description of the PGM format can be found here.
Don't think XnView can show you the hex codes for the pixels.
A hex editor would probably be better for that purpose.
Hexplorer is a freeware hex editor that I can recommend. It can be found here.
Lostclown
Re: PGB format
pizza wrote:I have the following question. First of all what is PGB? Is it a greyscale image?
You an use "View as hexa", or "Display color information".
pizza
Post by pizza »
Many thanks for you reply! Please tell me, the file below is a standard plain PGM? I need to recognize this "plain text". So, what are necessary attributes of this file? Is # feep.pgm a commentary? And what is P2?
Very waiting on your reply.
P2
# feep.pgm
24 7
15
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 3 3 3 3 0 0 7 7 7 7 0 0 11 11 11 11 0 0 15 15 15 15 0
0 3 0 0 0 0 0 7 0 0 0 0 0 11 0 0 0 0 0 15 0 0 15 0
0 3 3 3 0 0 0 7 7 7 0 0 0 11 11 11 0 0 0 15 15 15 15 0
0 3 0 0 0 0 0 7 0 0 0 0 0 11 0 0 0 0 0 15 0 0 0 0
0 3 0 0 0 0 0 7 7 7 7 0 0 11 11 11 11 0 0 15 0 0 0 0
pizza wrote:Many thanks for you reply! Please tell me, the file below is a standard plain PGM? I need to recognize this "plain text". So, what are necessary attributes of this file? Is # feep.pgm a commentary? And what is P2?
P2
# feep.pgm
24 7
15
Yes # feep is a comment, and P2 the format of picture, here a greyscale ascii file!
Lostclown
Re: PGB format
Post by Lostclown »
xnview wrote: You an use "View as hexa", .....
Yet another feature of XnView I was not aware of :)
Actually I didn't even think of looking for it in XnView.
Great.
Lostclown
