Large Font Size for Home Theatre PC
paul_ahb
Post by paul_ahb »
The system that I am intending on using XnView on is a Home Theatre PC (HTPC). Consequently it is only attached to a TV and hence font sizes have to be pretty big to make them easily legible (and yes, I am aware of DPI and "Extra Large" fonts under XP).
Could it be possible to add the functionality of changing the font size?
Paul
Re: Font Size
paul_ahb wrote:The system that I am intending on using XnView on is a Home Theatre PC (HTPC). Consequently it is only attached to a TV and hence font sizes have to be pretty big to make them easily legible (and yes, I am aware of DPI and "Extra Large" fonts under XP).
If you change the font size of system, XnView will have the same font size...
No?
paul_ahb
Post by paul_ahb »
You are right. I was hoping that the font size could be indepandantly controlled in XnView so I could set it to a size that would be rediculous for the windows shell (eg 20point).
Paul
