Crash while writing IPTC
bripriuk
Post by bripriuk »
Hi
I'm adding IPTC data to large numbers of camera files. If I try to add to more than about 250 files (500mb), the program always hangs.
XP, Athlon X2 64, 2 Gig Ram, latest version (also happened with previous version)
Brian
Re: Crash while writing IPTC
bripriuk wrote:Hi
Hangs or take long time?
bripriuk
Post by bripriuk »
Hi Pierre
I'm pretty sure it is hanging. I get a 'Program not Responding' when I try to close it, and The IPTC info has always been added to about the same number of files (200+). If I process in batches of 200, it works fine.
Brian
Troken
Post by Troken »
bripriuk wrote:Hi Pierre
Brian
Sometimes I've experienced "program not responding" when closing busy software, but it was actually still running – trying to close it crashes it. Maybe if you leave it for a while? I think XnView is slow with IPTC.
I've tried on 1200 files, and no problem. Your files are all in jpeg?
Perhaps there is one file that xnview can't update??
bripriuk
Post by bripriuk »
Hi Pierre
I think the files are all fine, as I was able to do it in batches. They were large camera files and I had other programs open, so it may be a memory problem.
I don't need to do any more large batches for a while, so it's not urgent.
Brian
bripriuk
Post by bripriuk »
One more quick one - how about a keyboard shortcut for Batch Rename?
Brian
bripriuk
Post by bripriuk »
Sorry - Just found f2 for re-naming
Brian
