As I am a beginner, I am not sure to have installed correctly XnView pocket with WM5 (Thanks Pierre for this super program !):
I ran the installer, and copied all the .cab files.
Now I have on my memory card : app, com, dev, jam, Program files, sys and the files midp, target and xnpocket_xsc...
Should I keep all that ?
2- Now after I used XnView, the system often stops (WM5) and I must reset it.
Thanks for your help,
Patrick
XnView pocket installation
Patrick ROOS
Re: XnView pocket installation
By isntalling XnPocket.cab, you have all these folders??? Do you have tried by the setup EXE?Patrick ROOS wrote:As I am a beginner, I am not sure to have installed correctly XnView pocket with WM5 (Thanks Pierre for this super program !):
You have installed the XSCALE version?2- Now after I used XnView, the system often stops (WM5) and I must reset it.
Patrick ROOS
Patrick ROOS
XnView Pocket v1.35
Hi, Pierre, many thanks for your help to a real beginner.
Yes I used the setup exe (installer)on my PC, but I also copied the cab file on my mobile and unziped it there.
Should I do so ?
This is probably why I now have all these folders and files on my memory card ?
I guess I did something wrong because WM5 regularly stops after using XnView.
Thanks again,
Patrick
Should I do so ?
Thanks again,
Patrick
Re: XnView Pocket v1.35
You must not use EXE setup AND CAB package...Patrick ROOS wrote:Hi, Pierre, many thanks for your help to a real beginner.
Should I do so ?
If you download the EXE setup, simply click on it to install xnview pocket on your pocket!
Patrick ROOS
Patrick ROOS
XnView Pocket v1.35 for WM5
Now I have re-intalled it correctly with setup exe (Xscale).
I really appreciate this excellent program.
However on WM5, XnView pocket works very well, but after I have stopped using it (click on windows red cross in right corner) then WM5 does not respond anymore, until I make a new general reset.
Thanks, Patrick
Thanks, Patrick
