ImageSkill has released Translucator 1.0 - Photoshop-compatible plug-in for translucent objects (fur, smoke, glass, haze, wool etc) extraction. With the release of Translucator, ImageSkill continues line of masking tools. Using Translucator you can make a result that is unavailable with other masking programs - Adobe Magic Extractor, Corel Knock-Out, Microsoft Expression and so on. You do not need accurately draw out an object. Mark semi-transparent area and press Apply.
Features at glance
• Ability to cut translucent objects like glass, fog, smoke, fur etc
• Color unmixing for background replacing
• There are tools for debris removing and holes filling within received mask
• You can switch between original image and result one and preview the extracted object against a colored matte background for result checking.
• 16-bit mode support
Translucator is a shareware, free 30 days/uses fully functional demo version you can download online: Download Demo version
Product page: http://www.imageskill.com/translucator/ ... cator.html
User’s Manual (in PDF): http://www.imageskill.com/translucator/tr_manual.pdf
Thanks,
Dmitry
ImageSkill Software
ImageSkill Translucator: new tool for translucent objects e
- Contact:
ImageSkill - Software for Digital Image Processing
