Error Message when i scroll to the next picture.
MacThunder
Post by MacThunder »
I love Xn-View but with my new PC i have this error.
(It's a AMD X2 4200+, with 1GB DDR2 Ram and Windows XP SP2 (not the x64 edition))
When i Open a Picture and dann scroll or press the next button i become a error message and xn-view close.
here are the error messages:
my english is not very well, i'm from austria you can see it on the pictures ;)
thx for help
kind regards
MacThunder
Wolf
Post by Wolf »
I have the same situation with XnView.
But when I double-click my image, XnView started then has a error occured.
Is it the codecs crash? or other reason?
thank you!
marsh
Post by marsh »
Try disabling "Read Ahead" option.
Post by Guest »
marsh wrote:Try disabling "Read Ahead" option.
Sorry, I can't find that option....
But I found that if I both install WMP11 beta & WMV9VCM
Perhaps XnView may crash~
If I install just only one, XnView will work fine...
So it will be codecs problems? ( WMV11 & WMV9 crash each other? )
Post by Guest »
Thank you, marsh!
I found that option!
And the situation never come back!!!
thank you very much!!!!
MacThunder
i have allsou found the option
now it works fantastic
big thx :D
