Hello Pierre:
about
http://newsgroup.xnview.com/viewtopic.php?t=5162
Hello Pierre,
ok, i try again:
- Set option "Fit image to window height"
- Resize the viewer window by using the size grip (lower right corner of the window),
Now, when you scroll through your images eg, using PgDown or Wheel mouse,
each image's height will be calculated to fit within this predefined/fix window height the user did set.
The image's width will be recalulated too, of course.
But as of now, normally the recalculated image's width differs from the window width, which stays fix.
So, actually the image will be either centered or truncated (scrollbars).
I would very like to have an additional option for to adapt the window width to the images width;
something like "Fit image to window height; variable window width"
Window height: fix, eg. set once by size grip
image's height: stretched to window height
image's width: calculated proportionally
Window width: variable, depends on image width
It's already on the todo list, i only tried to ask for the chance ...
Best Regards,
klaus2
Answer to: Requests: renewed: Fit image to window height wit
