RC1 - Mouse navigation does not work in Slide show [RC5-OK]
Mouse navigation in slide show don't works, keybord navigation works good.
Re: Mouse navigation in slide show don't works
With a timer?Dreamer wrote:Mouse navigation in slide show don't works, keybord navigation works good.
Yes.xnview wrote:With a timer?Dreamer wrote:Mouse navigation in slide show don't works, keybord navigation works good.
There never was navigationDreamer wrote:Yes.xnview wrote:With a timer?Dreamer wrote:Mouse navigation in slide show don't works, keybord navigation works good.
But navigation with keybord works, with mouse not whyxnview wrote:There never was navigationDreamer wrote:Yes.xnview wrote: With a timer?
Ok, i add itDreamer wrote:But navigation with keybord works, with mouse not why![]()
Greatxnview wrote:Ok, i add itDreamer wrote:But navigation with keybord works, with mouse not why![]()
Sometimes people want to have a demo mode which should not be interrupted by using the mouse or keyboard. So it would be good if there was an option to disable both mouse and keyboard. Sure enough, the 'Esc' key (or ideally a definable key combination) for stopping the slide show should be available.xnview wrote:Ok, i add itDreamer wrote:But navigation with keybord works, with mouse not why![]()
Not sure whether there is a real need for this, but I would find this useful.
But if they use another application, xnview isn't active, so using of keyboard or mouse don't stop slide show, or am I wrong?helmut wrote:Sometimes people want to have a demo mode which should not be interrupted by using the mouse or keyboard...
Navigation with mouse buttons works now, but I don't use itxnview wrote:Ok, i add itDreamer wrote:But navigation with keybord works, with mouse not why![]()
Navigation with mouse scroll still don't works
Minor - hotkeys "Home" and "End" don't works here too.
Thank you very much.
Ok, i add it.Dreamer wrote:Navigation with mouse scroll still don't workseven Minor - hotkeys "Home" and "End" don't works here too.
In slide show?middle mouse button for exit fullscreenCan you fix it, please
Thank you!xnview wrote:Ok, i add it.Dreamer wrote:Navigation with mouse scroll still don't workseven Minor - hotkeys "Home" and "End" don't works here too.
Yes, sometimes is useful to exit slideshow with a mouse...xnview wrote:In slide show?Dreamer wrote:middle mouse button for exit fullscreenCan you fix it, please
It's normally works (not in slide show)
All these features were added in RC5 - thank you very muchxnview wrote:Ok, i add it.Dreamer wrote:Navigation with mouse scroll still don't workseven Minor - hotkeys "Home" and "End" don't works here too.
