"Save As Dialog"
bbi
"Save As Dialog"
Post by bbi »
Hi all,
I am using Version 1.82.4. When I using the function "save as"/"Speichern unter" there is a button (right to "Create new Folder" where I can chose List/Details/Symbols/../...
The Default setting ist List. When I change the setting to details the details information appears - so far as good.
Unfortunately the setting is getting lost when I want to save the next picture (I scan 1000 and more of documents each year).
Additional: Is it possible to use the "Save as" dialog which is used e.g. from MS Office. There I can define severals Targets (Folders) in the Placebar to store pictures faster.
Best Regards,
Boris
Not even "2"
:) Hello !
…Additional: Is it possible to use the "Save as" dialog which is used e.g. from MS Office. There I can define severals Targets (Folders) in the Placebar to store pictures faster.
• Please, give a glance there (the lower image)… and further in the thread.
- I requested only two target-folders, but … :|
- Your idea sounds good, but I fear that this box belongs to MS-Office,
hence the users who have not any Office (i.e. myself) couln't get it…
:mrgreen: VG
Re: Not even "2"
Post by Guest »
Clo wrote: - Your idea sounds good, but I fear that this box belongs to MS-Office,
Hi Claude,
as I know the (maybe I am wrong) the feature "Save as" belongs to the operating system (In my case XP). You can see that also when you use "notepad".
Best Regards, Boris
PS: Thanks for the link I will check if it fits to my requirement
