IPTC processing with NConvert?
nightflyer
Post by nightflyer »
Please add possibility to read/set IPTC fields.
Something like:
prints "This is my dog"
sets the field
clears field
An option can be read options from file, like:
-iptcbatch batch_file.cmd
And batch_file.cmd contains lines like:
Option to skip setting value if field is already set.
-=nightflyer=-
Re: IPTC processing with NConvert
nightflyer wrote:Please add possibility to read/set IPTC fields.
Something like:
sets the field
clears field
Yes, will be good...
Mistic100
Post by Mistic100 »
So,
and now 4 years later
are these functions still in project ?
Mistic
Mistic100 wrote: and now 4 years later
yes i know :(
Re: IPTC processing with NConvert?
Mistic100
Post by Mistic100 »
Is there a doc about how to use -iptc_* params ?
Mistic100 wrote:Is there a doc about how to use -iptc_* params ?
you have nconvert -help only :(
Mistic100
Post by Mistic100 »
because I tried this:
nconvert.exe -iptc_print Keywords "img.jpg"
nconvert.exe -iptc_print 25 "img.jpg" (25 is the id of the keyword field)
nconvert.exe -iptc_print IPTC.Application2.Keywords "img.jpg" (as in exiv2)
All unsuccessfully :(
Mistic100 wrote:because I tried this:
To be able to use -iptc_print you must use -info
and the good one is
Mistic100
Post by Mistic100 »
ok it works
but nconvert can't add/set iptc tags without reprocessing the picture ?
if not I will continue to use exiv2 :?
Mistic100 wrote: but nconvert can't add/set iptc tags without reprocessing the picture ?
Oh, you would like to make lossless iptc editing??
Mistic100
Post by Mistic100 »
I don't know if lossless is the good term, but just add tags, without touch the rest of the file
exiv2 can do it (I compared the two picture, they are exactly the same, just a difference of 10 Bytes for a 6 chars lenght tag) so why not nconvert ?
ps : I don't really like exiv2 ^^ its application is very specific and the exe is 3,4MB and must come with a .dll
Mistic100 wrote:I don't know if lossless is the good term, but just add tags, without touch the rest of the file
Ok, i'll add such feature with beta 2
Could you try NConvert in XnView 1.98 beta 2 package?
