I am having trouble opening an HPI file in XnView. The file is being created by Hemera Photo Clip Art program. XnView does not seem to recognize it. I am using version 1.82.4 It is the full version with all plugins. I have gone to options >> General >> Startup >> and I have enabled "Use all formats available" When I navigate to a "hpi" file and double click on it, it will not bring it up in the viewer window. Also, when I try to select the file for converting, I get an error that states it could no open file.
Any help would be great. Thanks.
Help with HPI format
Re: Help with HPI format
Could you send me it?Mike wrote:I am having trouble opening an HPI file in XnView. The file is being created by Hemera Photo Clip Art program. XnView does not seem to recognize it. I am using version 1.82.4 It is the full version with all plugins. I have gone to options >> General >> Startup >> and I have enabled "Use all formats available" When I navigate to a "hpi" file and double click on it, it will not bring it up in the viewer window. Also, when I try to select the file for converting, I get an error that states it could no open file.
