i'd like to decide in which order the toolbar button should be.
is it possibile?
change buttons positons in the toolbar
Re: change buttons positons in the toolbar
In the next release...Tommy wrote:i'd like to decide in which order the toolbar button should be.
is it possibile?
Tommy
D&D---
—> Tommy
Hello !
• Why don't you check by yourself ?
- The good easy way to change the positions of the buttons in the Options is indeed via Drag & Drop,
like in Total Commander…
…and that doesn't work yet in 1.90 A 3, as far as I see.
- Hoping that Pierre will use that method… and give us icon-previews showing the real sizes…
KR
