Hello!
These days, there was a Microsoft-Bug with JPEG-Images, who can
cause a buffer overflow and insert some code.
What happens, if such a manupulated JPEG-Image is opened with xnview?
No danger at all? Or depends it on the windows-version?
Regards,
Lasse
JPEG: Danger also with xnview?
Lasse
Re: JPEG: Danger also with xnview?
I don't think that there is a problem, because microsoft don't use the same library, and if you open a such jpeg with xnview, what's happened? Nothing, only perhaps a crash of xnview.Lasse wrote:These days, there was a Microsoft-Bug with JPEG-Images, who can
MaierMan
Tested with sample found at:
http://www.easynews.com/virus.html
With XNView 1.70 you simply see the regular jpeg-file-icon (no thumb).
You cannot open it with xnview... Says that the format cannot be determined.
The image itself doesnt contain valid image data for what I read. Thus its correct that nothing was displayed.
No crashes.
I dont think Pierre just copied pretty old Netscape code.
Thus no bug
(While MS seems to have done exactly this
PS: Norton Antivirus 2004 was found it via auto-protect...
Saying it was found thru Bloodhound.
No crashes.
Thus no bug
