If I want to make a screenshot it is usually only of other programs than XnView. So I have my application, open XnView for the capture, select Capture... Then I select the setting window and the preselected window is always XnView. So I have to switch to the second window in the list.
My suggestion: The default window should not be XnView but the next window in the list. Maybe it would even be possible to save the last used window.
Anika
Capture setup window - preselected window
Anika
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Re: Capture setup window - preselected window
Ok, i'll change itAnika wrote:If I want to make a screenshot it is usually only of other programs than XnView. So I have my application, open XnView for the capture, select Capture... Then I select the setting window and the preselected window is always XnView. So I have to switch to the second window in the list.
Perhaps....My suggestion: The default window should not be XnView but the next window in the list. Maybe it would even be possible to save the last used window.
