Export function should remember last chosen format
Not sure if this qualifies as a bug or a feature request or just an oversite, but the export function should remember the last format you selected instead of always reverting to JPEG. It's not a major thing, but it can get quite annoying if you're exporting multiple PNGs or JPEG2000s or something.
						Re: Export function should remember last chosen format
Good point. This is a good improvement for the new Export functionality of Alpha 3 version - exactly what this group "Alpha Feedback" is for.Drahken wrote:Not sure if this qualifies as a bug or a feature request or just an oversite, but the export function should remember the last format you selected instead of always reverting to JPEG. It's not a major thing, but it can get quite annoying if you're exporting multiple PNGs or JPEG2000s or something.
