When tree pane tabs is disabled the Favourites and Gategories panel is disordered.
1. Disable tree pane tabs with "View > Tree pane > Use tabs"
2. Restart XnView (not required, but the bug is more notable after restart)
3. Open Favourites or Categories panel "View > Tree pane > ..."
Edit: http://i15.tinypic.com/2eobq06.png
B1: Tree pane without tabs
ckv
ckit
ckv
Yes that too, but I really meant bug like this http://i15.tinypic.com/2eobq06.pnghelmut wrote:Confirmed, here. When hiding or showing the tree pane, the category is always switched back to "Folders".
Re: B1: Tree pane without tabs
And you don't show again tree pane??? Strange, i can't reproduce it...ckv wrote:When tree pane tabs is disabled the Favourites and Gategories panel is disordered.
3. Open favourites or Gategories panel "View > Tree pane > ..."
During the whole session the tree pane is visible, only the tabs are hidden. If you follow the steps it should be easy to reproduce the problem (unless it is specific to Windows XP).xnview wrote:And you don't show again tree pane??? Strange, i can't reproduce it...ckv wrote:When tree pane tabs is disabled the Favourites and Gategories panel is disordered.
I can't reproduce it on win 2K or Xphelmut wrote:During the whole session the tree pane is visible, only the tabs are hidden. If you follow the steps it should be easy to reproduce the problem (unless it is specific to Windows XP).xnview wrote:And you don't show again tree pane??? Strange, i can't reproduce it...ckv wrote:When tree pane tabs is disabled the Favourites and Gategories panel is disordered.
marsh
Confirmed.
1. Disable View > Tree pane > Use tabs
2. Select View > Tree pane > Favourites
3. *Ghost image is seen in tree tab area.
4. *<alt + tab> to another program and return to Xnview to see other desktop images as ghosts.
Layout #3
It also makes ghost images in viewer:
(same bug?)
5. Import clipboard and see it in viewer.
6. Press zoom 100 % <*>
7. Press zoom fit to window </>
8. *Ghost image seen here also.
Layout #3
(same bug?)
confirmedmarsh wrote:Confirmed.
Can't reproduce itIt also makes ghost images in viewer:
(same bug?)
ckv
Fixed in beta 2. marsh please retest too. Thanks Pierre and all.
marsh
