Steps:
1. Open XnView in Browser mode
2. View menu -> Show Files in Subfolders
3. All images in subfolders is shown.
4. View menu -> Show Files in Subfolders (2nd time)
5. All images and subfolders are gone completely!
B1: Show Files in Subfolders bug
ckit
Bistable and buggy
• Confirmed here too.
- This command works as "bistable" - that is not so bad and usual for a “Branch view”,
but it is not shown such as in the menu (it should).
- On a second action, might display again the prior thumb nails board…
ckit
Fixed in Beta 2.
However, if you press Refresh after the 2nd Show Files, you have a empty pane with no files!
Choosing Refresh should reload the folder as it was at the start.
Olivier_G
ckit
Fixed in Beta 3,ckit wrote:Fixed in Beta 2.
although all files and folders are selected for some reason?
marsh
I don't see that problem.ckit wrote:Fixed in Beta 3,ckit wrote:Fixed in Beta 2.
ckit
Ok my steps:
- Open XnView in Browser mode
- Move to a folder that has other folders with images in them
- View menu -> Show Files in Subfolders
- View menu -> Refresh
- All folders and files are selected!
marsh
It occurs with:ckit wrote:Ok my steps:
[x]Automatically select new files.
ckit
