B1: Batch Convert Fav-Icon Gui bug
ckit
Post by ckit »
I just noticed there is a small black box behind the star icon for favourites in the Batch dialog, is this a new default look or a bug?
It also effects the "Copy To" and "Move To" dialogs as well.
marsh
Post by marsh »
I don't see it on Win2k.
Olivier_G
Post by Olivier_G »
It seems to depend on the Skin selected in the Options... :|
(same thing for the thumbnails' icons... although those are updated only on XnView start)
Olivier
ckit
Post by ckit »
Olivier_G wrote:It seems to depend on the Skin selected in the Options... :|
Yes, you are correct.
I've returned to the default skin until this is fixed.
Mezich is black and Crystal Clear is white :(
ckit
Post by ckit »
Fixed in Beta 2.
