The levels now range from 0 to 10.
Shouldn't it be 0 (none) to 9 (maximum) as it used to be in prior versions?
B1: PNG Compression Levels
- Forum Librarian
marsh
Re: B1: PNG Compression Levels
I think you're right. 0-9 is zip like scale I'm used to seeing. 9 and 10 produce equal size files for me, though 10 seems redundant.XnTriq wrote:The levels now range from 0 to 10.
Drahken
9 is the maximum, 10 is some sort of error. However, it has existed in the export function in beta, alpha, and even back in xnview deluxe. It seems to be a mostly cosmetic error, since it appears to actually be using level 9 regardless whether you set it at 9 or 10.
ckit
- Forum Librarian
- Forum Librarian
