Print dialog bug
Troken
Print dialog bug
Post by Troken »
This bug occured in A3 aswell, but don't remember reporting it.
1. Select an image.
2. Print. In the print dialog, my default page layout is "Best fit to page". Looks good so far.
3. Go to the "printer"-tab, and change printer.
4. Go back to the "layout"-tab. The page layout is still "Best fit to page" the image does not fit the page anymore. It can be scaled way to big or have become smaller. To correct it, you have to select "Best fit to page" again, although its already selected!
I tried to print without reselecting "Best fit to page", thinking it was just a matter of some previewbug, but no, XnView prints with the new bad scaling.
Please look at the image comparison. http://members.chello.se/troken/XnView/ ... change.jpg
Olivier_G
Post by Olivier_G »
Confirmed.
Olivier
Olivier_G
Post by Olivier_G »
Solved in Beta 2.
Troken: can you please confirm, just to be sure?
Olivier
Troken
Post by Troken »
Yes, it seems to work properly now. :)
