I'm looking at XnView for the first time, looking for a replacement for PaintShop Pro which has gotten seriously bloated. I tried Paint.Net but that is lacking features I need.
So far I like XnView but one question
Even though XnView appears to be a MDI application, being able to view multiple images in a single instance of itself every time I click on an image in explorer or launch an image from an application like my newsreader, Agent, it launches a new instance of XnView.
Is there a way I can get it to load the image in the already loaded instance of XnView?
I'm using WinXP SP2 with all the updates and the latest XnView
thanks
mike
How do I get XnView to launch only 1 instance?
thanks, I had tried a couple searches in the forum and didn't find anything, then decided to try and few others after I posted and immediately found this threadmarsh wrote:Options... General>Startup>[x]Only one instance
http://newsgroup.xnview.com/viewtopic.p ... ght=launch
thanks
mike
