REQ: Custom Folder for Save Options
ckit
Post by ckit »
I would like to be able to specify a custom folder for both "XnView's INI" and "Folder used for other files"
Basically I want to put all of XnView's configuration somewhere else where the next install of XnView won't wipe them out.
Currently, I can only do this with the toolbar and the thumbnail cache.
XnView 1.90 <x>
Already---
:) Hello Chris !
• I support, I'd already requested something in that painting HERE 3 months ago - at least for the INI file- quite unsuccessfully…
- It's incomplete, indeed a [•••] browse button is missing for the INI :|
• I posted the same in the French forum with an image in French, nope…
:mrgreen: KR
ckit
Post by ckit »
It's ok, Clo.
I'm using "user" for INI and the "other files" now.
Keeping your files in XnView's main program folder is a huge mistake, learnt the hard way.
Dreamer
Post by Dreamer »
I support this request.
...But moving to "- Feedback".
BTW I install some programs to other folder/disk, not to C:\Program Files, then it works even after Windows reinstall and settings are not lost.
Dreamer
