B1 Fit image to window height; var width; top and left pos
klaus2
Post by klaus2 »
I'm very happy about the new fit mode "Fit image to window height; var width" :-)
Only a little thing about:
- the left pos of the window should be kept like the user did set it (no centering of the viewer window within the screen)
- the top pos of the window should be kept like the user did set it (no top alignment of the viewer window).
In that regard (left and top pos) it should behave like in the established "Fit image to window height" for to preserve the user's control.
(reasons in detail mentioned in http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
but i tried to shorten that long story a little bit )
Pierre, many many thanks for having implemented the original suggestion!
klaus2
klaus2
Post by klaus2 »
Correction in beta2 works exactly as expected;
excellent, great ..... many many thanks :-) :-)
klaus2
