I'd like to see XnView be able to slice images into pieces, save the pieces and create the html to piece it back together in a table.
You should be able to tell Xnview where the slices should be or set it to batch slice a bunch of images at once by telling it how many slices you want it would do it automatically and randomly.
This software apparently does it.
http://www.batchimage.com/product/batch ... index.html
This would be great for setting up images for a website and stop people from hotlinking to your images.
