permanently enable fit to screen option
Discussions on XnView for PocketPC
ohaak
Post by ohaak »
is there any chance to permanently enable the 'fit to screen' option for all images in XnView - not just images to big to display? The feature is always disabled after restarting the application.
I'm running XnView on a Pocket LOOX N560 in VGA resolution on WM5.
Any ideas?
Re: permanently enable fit to screen option
ohaak wrote:Hi,
Any ideas?
Ok, i'll add it
ohaak
Post by ohaak »
xnview wrote:Ok, i'll add it
Thanks Pierre - that's great!
