B1: Auto image size after acquiring image
eyebex
Post by eyebex »
in XnView 1.90 Beta 1 running under Win XP Pro SP2 32-bit, it seems the "Auto Image Size" settings are not applied after acquiring an image from a scanner via Twain.
Thanks :bug:
Re: B1: Auto image size after acquiring image
eyebex wrote:in XnView 1.90 Beta 1 running under Win XP Pro SP2 32-bit, it seems the "Auto Image Size" settings are not applied after acquiring an image from a scanner via Twain.
Which setting do you use?
eyebex
Post by eyebex »
I'm using "Fit image to desktop, large only".
This bug is still present in Beta 4. After acquisition, the XnView windows stays the same as before acquisition, and gets scroll bars because the acquired image is so large.
eyebex
Post by eyebex »
Confirmed to be fixed in B5.
