CCleaner (freeware)
All non-XnView related: softwares, formats, imaging, photography...
ckit
CCleaner (freeware)
Post by ckit »
CCleaner
Freeware system optimization and privacy tool. It removes unused files from your system - allowing Windows to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. But the best part is that it's fast (normally taking less than a second to run) and contains NO Spyware or Adware! :)
Cleans the following...
Internet Explorer, Temporary files, URL history, cookies, Autocomplete form history, index.dat.
Firefox, Temporary files, URL history, cookies, download history.
Opera, Temporary files, URL history, cookies.
Windows, Recycle Bin, Recent Documents, Temporary files and Log files.
Registry cleaner, Advanced features to remove unused and old entries, including File Extensions, ActiveX Controls, ClassIDs, ProgIDs, Uninstallers, Shared DLLs, Fonts, Help Files, Application Paths, Icons, Invalid Shortcuts and more... also comes with a comprehensive backup feature.
Third-party applications, Removes temp files and recent file lists (MRUs) from many apps including Media Player, eMule, Kazaa, Google Toolbar, Netscape, MS Office, Nero, Adobe Acrobat, WinRAR, WinAce, WinZip and many more...
100% Spyware FREE, This software does NOT contain any Spyware, Adware or Viruses.
Download: http://www.ccleaner.com/download/
Homepage: http://www.ccleaner.com/
ckit
Post by ckit »
CCleaner 1.36.430 has been Released!
v1.36.430
- Fixed bug with Hotfix and logfile cleaning.
- Added Office 2007 cleaning.
- Minor tweaks and optimizations.
ckit
Post by ckit »
CCleaner 1.38.485 has been Released!
v1.38.485 - [7th Mar 2007]
- Fixed resize crash at very high resolutions.
- Optimized Firefox cookie cleaning.
- Fix bug with language setting in INI file.
- Scanning performance tweaks.
- Updated several translations.
- Added support for IE protected mode cookies.
- Vista compatibility fixes.
- Minor bug fixes.
ckv
Post by ckv »
CCleaner Portable
There's also portable version (of which code I'm responsible for) for CCleaner.
http://forum.piriform.com/index.php?showtopic=5707
Edit: Oh. There is also alternative builds for CCleaner.
CCleaner - Basic
- No Yahoo toolbar
CCleaner - Slim
- No Yahoo toolbar
- English Only
http://www.ccleaner.com/download/builds.aspx
Edit2: Also check out the Winapp2.ini for additional cleaning power. :D
http://forum.piriform.com/index.php?showtopic=1110
Lesmo16
Post by Lesmo16 »
ckv, thanks for these informations! :)
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
CCleaner 1.39.502 has been Released!
v1.39.502 - [17th April 2007]
- Rewritten secure deletion code, now over 2x faster.
- Performance improvements deleting Internet Cache.
- Fixed bug in Recycle Bin cleaning.
- Fixed overflow error with a large number of temp files.
- Added AntiVir PE Classic and Premium cleaning.
- Removed PerfectDisk 8.0 cleaning.
- Optimized file size for language DLLs.
- Added Bosnian translation.
- Added Macedonian translation.
- Minor bug fixes.
ckit
Post by ckit »
CCleaner v2.01.507
- Fixed bug where some IE Temporary files were not being removed.
- Fixed bug with IE7 Recently Typed URLs cleaning.
- Fixed C++ exception on Desktop shortcut scanning.
- Installer now works on 64-bit OS Recycle Bins menus.
- Optimized IE Temp files cleaning speed.
- Improved index.dat cleaning on XP.
- Fixed Registry Cleaner as "Fix All" sometimes wouldn't work.
- Keyboard shortcuts now work correctly in Registry section.
- Files winsys.ini and winreg.ini are now embedded in ccleaner.exe.
- Fixed bug where Autoupdate check could cause an exception.
- Fixed minor bug in restoring screen position and size.
- Lots of internal improvements to reliability and speed.
- Minor UI tweaks.
ckit
Post by ckit »
CCleaner v2.02
- Application is now 100% Unicode, with support added for non-Unicode OSs.
- Fixed bug where some IE temp files were not being securely deleted.
- %LocalAppData% and %CommonAppData% variable support added to INI files
allowing "Application Data" references to work on non-English versions
of Windows.
- Fixed bug where "Run (in Stat Menu)" was being cleaned when deselected.
- Added Gutmann (35 pass) secure deletion.
- Fixed minor bugs with 98 and NT4.
- Fixed bug with update checker.
- Added "portable.dat" file to the portable version of CCleaner, which
forces it to save the settings to an INI file.
- Fixed bug in cookie scanning that could cause an exception.
- Fixed minor UI bugs relating to control and window focus.
- Improved exception handling with more useful information.
- Minor bugs fixes and tweaks.
ckit
Post by ckit »
CCleaner v2.03
- Improved support for IE7 Autocomplete cleaning.
- Added Vista Recycle Bin secure deletion.
- Fixed bug in secure deletion of filenames.
- Fixed bug in "Other Explorer MRUs" cleaning.
- Fixed minor bug in Temp file deletion.
- Added better secure deletion for cookies.
- Fixed Autocomplete cleaning on Win98.
- Improved Hotfix Uninstaller cleaning to ignore Desktop Search.
- Fix bug in saving CCleaner window position.
- Improved System Info routines.
- Minor bugs fixes and GUI tweaks.
ckit
Post by ckit »
[28th April 2008]
CCleaner v2.07
- Firefox 3.0 support added.
- Fixed bug where figures were missing for KB/MB sizes.
- Fixed bug where some IE cookies were being missed.
- Improved scan time accuracy.
- Internal memory management improvements.
- Registry settings moved to HKCU\Software\Piriform\CCleaner.
- Fixed bug where CC could get locked in System Tray.
- Renamed MSN Messenger to Windows Live Messenger.
- Added MS Office Picture Manager to applications.
- Fixed uninstaller tool bug on 64-bit OS.
- Minor GUI improvements.
- Minor bug fixes.
ckit
Post by ckit »
[29th May 2008]
CCleaner v2.08
- Added Startup tool enable/disable checkbox.
- Fixed problem with Vista "low" folders being removed.
- Improved index.dat detection on multiple scans.
- Secure deletion improved with IE History index.dat files.
- Added OS detection to INI files.
- Added Vista Thumbnail Cache cleaning.
- Added ImgBurn cleaning.
- Added Secure deletion to "Recent Documents" cleaning.
- Improved Vista "Recent Documents" cleaning.
- Fixed bug with Chkdsk chk files not being removed.
- Added "Select all" checkbox to header of Registry cleaner.
- Added sorting to Startup tool listview.
- Fixed Vista 64 issue with Startup tool.
- Added Croatian translation.
- Minor tweaks and GUI improvements.
ckit
Post by ckit »
[26th June 2008]
CCleaner v2.09
- Added full support for Internet Explorer 8.0 beta.
- Improved Opera 9.5 support to fix cache cleaning.
- Improved interface for Startup tool.
- Changed memory management routines to reduce footprint.
- Fixed rare 64-bit performance issues.
- Added splitter bar to interface.
- Fixed repaint issues with certain themes.
- Fixed Spybot cleaning detection.
- Internal code optimizations.
- Updated installer engine to fix icon bug.
- Minor GUI tweaks.
ckit
Post by ckit »
[30 July 2008]
CCleaner v2.10
- Added Type Library cleaning to Registry Cleaner.
- Improved File Extension scanning in Registry Cleaner.
- Added /SHUTDOWN command-line parameter to shutdown the computer
after cleaning. Only works with /AUTO.
- Added Shutdown option to system tray menu.
- Added support for Vista common dialogs.
- Fixed bug in Uninstaller Tool where some items were hidden.
- Fixed multi-monitor issue with dialogs.
- Fixed incompatibility with Windows Search 4.0.
- Added seconds to filename when saving .REG files.
- Improved RegEdit location navigation.
- Improved Google Earth cleaning and detection.
- Memory usage optimizations.
- Minor bug fixes.
Re: CCleaner (freeware)
Piriform Community Forums (MrG: [url=http://forum.piriform.com/index.php?showtopic=41841&p=253662]CCleaner v4.18[/url]) wrote:
Change log:
  • Added Active System Monitoring for Free users
  • Improved Firefox Saved Password cleaning
  • Improved Opera History cleaning
  • Improved 64-bit build architecture for Window 8 and 8.1
  • Added Ashampoo Burning Studio 14, XnView and FastStone Capture cleaning
  • Improved localization support
  • Minor GUI Improvements
  • Minor bug fixes
[color=green]CCleaner.exe[/color] wrote:
[XnView]
ID=2406
LangSecRef=3024
Detect=HKLM\Software\XnView
Default=True
FileKey1=%AppData%\XnView|XnView.db;category.bak
FileKey2=%ProgramFiles%\XnView|category.bak
FileKey3=%LocalAppData%\VirtualStore\Program Files*\XnView|category.bak
FileKey4=%ProgramFiles%\XnView\cache|*.db
FileKey5=%LocalAppData%\VirtualStore\Program Files*\XnView\cache|*.db
bdragon ([url=http://newsgroup.xnview.com/viewtopic.php?t=35708]XnView MP and CCleaner[/url]) wrote:Went into the CCleaner settings today. To see what was new as i had not changed them in a few sections.
After that XnView MP stopped working. Had to re-install it as even a reboot did not solve the problem.
Went back and checked everything i did.
So: if you use Ccleaner and want to be able to keep using XnView MP... DO NOT check this option:
cleaner > Applications > (Windows) Session Manager.
Removing this single tick also solved several problems i was having since this morning of which i did not know the causes. Including computer-stopping bugs when using chrome at 100% processor use.
Xnout!
Post by Xnout! »
So, what's the point of that last post?
Is there some specifiic issue with people running v4.18 or older versions?
The current version is 5.30.
Also, to bdragon,
I've been running CCleaner for many years and don't remember a Session Manager setting.
is that something new to v5.30 (I'm using 5.28)? Do you mean MS Management console?
Thanks
