The Add folder option in Cache creates thumbs also for hidden folders, which are currently excluded from normal thumbnailing, at least because they're set not to be displayed and you cannot browse inside them.
I believe the same filters should apply as with normal browsing: if hidden folders are not displayed, they shouldn't be thumbnailed by the Add folder feature.
B1: Add folder thumbs hidden folders
