This one is related to tag function:
1. Tag one file in a subdirectory.
2. Use up icon to move to parent directory.
3. Select batch convert with <ctrl + U>
4. *Now all files in original subdirectory are placed batch convert's listing.
B2: Wrong files used for batch convert.
marsh
Re: b2: Wrong files used for batch convert.
Because you have no more selected or tagged files... When you quit the current folder, tagged files are removed...marsh wrote:This one is related to tag function:
Re: B2: Wrong files used for batch convert.
I cannot reproduce this problem, neither with Beta 2 nor with Beta 3. For me, after step 3 the convert's file listing is empty, which is correct.marsh wrote:4. *Now all files in original subdirectory are placed batch convert's listing.
marsh
Perhaps you have discovered a Win2k vs. XP issue then.helmut wrote:I cannot reproduce this problem, neither with Beta 2 nor with Beta 3. For me, after step 3 the convert's file listing is empty, which is correct.marsh wrote:4. *Now all files in original subdirectory are placed batch convert's listing.
I've just tried on Windows 98 (which is related to Win2k) but could not reproduce the problem either.marsh wrote:Perhaps you have discovered a Win2k vs. XP issue then.
Could you please check option "If no files are selected ..." in Tools > Options > General > Misc. ? My setting is "None" for both "Slide show" and "Convert.
marsh
Same setting (None) for me. The setting works as expected in 'slideshow'.helmut wrote:I've just tried on Windows 98 (which is related to Win2k) but could not reproduce the problem either.marsh wrote:Perhaps you have discovered a Win2k vs. XP issue then.
marsh
