b2: Single click expands favourites.
marsh
Post by marsh »
Single click now expands favourites to show subfolders when the following option is disabled:
[ ]Single click to expand folder tree
GeorgD
Post by GeorgD »
Huh? You're talking about Options -> Browser -> Folder Tree -> [ ] single click to expand folder tree? I've understood it that way that this option does not at all refer to favourites (indeed it has no affect on the behaviour of favourites), but to the folder view, and there it has the correct effect.
marsh
Post by marsh »
Improved in ß-3.
GeorgD wrote:Huh? You're talking about Options -> Browser -> Folder Tree -> [ ] single click to expand folder tree? I've understood it that way that this option does not at all refer to favourites (indeed it has no affect on the behaviour of favourites), but to the folder view, and there it has the correct effect.
Favourites were single-click expand in ß-2.
They are now double-click expand in ß-3, so it operates more like other folders.
The question: "Should '[x]Single click to expand folder tree' apply to favourites?" is being discussed by Dreamer in following topic:
http://newsgroup.xnview.com/viewtopic.php?t=10826
