Two delete questions
mike
Post by mike »
Is there a way to get Delete on the toolbar?
And is there a way to have the images window in XnView to close after delete?
I'm using version 1.82.4 on WinXP SP 2
thanks
mike
foxyshadis
Post by foxyshadis »
In options, toolbar section, switch to view mode. Then you can hit append, choose cmd_Delete for the action, find an icon if your skin doesn't have one, and reposition as you wish. (I just realized, this might be a 1.90 feature only. I can't remember.)
Don't believe the latter is possible at this time.
foxyshadis wrote:In options, toolbar section, switch to view mode. Then you can hit append, choose cmd_Delete for the action, find an icon if your skin doesn't have one, and reposition as you wish. (I just realized, this might be a 1.90 feature only. I can't remember.)
Yes, a new feature of the 1.90 beta...
Post by Guest »
xnview wrote:Yes, a new feature of the 1.90 beta...
How do you get the tab/image to close after deleting it in 1.90?
I was able to add delete to the toolbar using 1.90 beta 3 but I don't see how to get the image to close after I hit delete
thanks
mike
Post by Guest »
How can I get the image to close (it's tab) after deleting it in 1.90?
I searched around a bit and couldn't figure out how.
thanks
mike
Anonymous wrote:How can I get the image to close (it's tab) after deleting it in 1.90?
Currently there is no way to close viewer after deleting it
