Saving Options (Keyboard/Mouse settings)
When I change the keyboard option:
[Cursor Up/Down] to (Scroll Up/Down) from (Previous/Next Frame)
and press [OK] it works fine. However, when I reopen the options dialogue, the option is reset to [Previous/Next Frame].
I hope this helps.
Hiding the scrollbar in regular window view mode
when you hide the scrollbar, and an image exceeds the height (and possibly width) of the window, it leaves a blank spot in the window where the scrollbar would have been if it were visible. I don't know if this was intentional, but I find it annoying.
And also, PLEASE ADD AN OPTION TO CUSTOMIZE UP/DOWN & LEFT/RIGHT SCROLL SPEEDS WITH THE KEYBOARD CURSOR KEYS. That's probably the only reason I never use XnView full time is because it takes so long to scroll from the top of an image to the bottom with the keyboard.
I know the second part was a suggestion, but I saw this same suggestion posted in the suggestion section in JANUARY 06, and this feature still hasn't been added (it's NOVEMBER 06 now).
V 1.90 <x>
Saving Options (Keyboard/Mouse settings) & etc.
Kallen
marsh
Re: B2: Saving Options (Keyboard/Mouse settings) & etc.
Confirmed.Kallen wrote:Saving Options (Keyboard/Mouse settings)
Function is right
• Yes, I confirm : the option shown is wrong, but the function set before is right : It scrolls Up¦Down still !
- I've closed¦restarted ß-2 to check this.
Dreamer
marsh
<Moderator's note: Please start a new topic for your additional problem/question - see Rules & Guidelines>Kallen wrote: Hiding the scrollbar in regular window view mode
Could you post a screenshot, please?Kallen wrote:Hiding the scrollbar in regular window view mode
Olivier_G
1. Works fine in Beta 6 for me.Kallen wrote:1. Saving Options (Keyboard/Mouse settings)
2. Hiding the scrollbar in regular window view mode
3. PLEASE ADD AN OPTION TO CUSTOMIZE UP/DOWN & LEFT/RIGHT SCROLL SPEEDS WITH THE KEYBOARD CURSOR KEYS.
2. I don't get this bug in Beta 6.
3. Postponed to improve the solution.
-> Could you please re-test 1 & 2 in Beta 6?
Olivier
I've posted Kallen's suggestion for scroll speed seperately in a new topic, see Scroll speed for cursor keys.
-> Closed.
-> Closed.
