keep user configuration from 1.82.4 to 1.90 beta
Tommy
Post by Tommy »
is it possible to keep 1.82.4 user settings and configs in the 1.90 beta 2 version?
GeorgD
Post by GeorgD »
For me, it worked from 1.82.4 to 1.90 alpha3. I assume it works for 1.9b2, too. However, you shall check the settings dialogues as some options changed or are new. Give b2 a try, it's a big improvement :-) of an already very good program.
foxyshadis
Post by foxyshadis »
I accidentally dumped everything by overwriting the ini, so watch out for that. (It was for the best in the end anyway, I think.) You can choose per-user settings in the options as soon as you upgrade, to prevent from being possible in the future.
