Today seems to be the day for them, eh? (I just found out xnview even has favorites.) It seems to really center around the idea of a folder being self-contained, no subfolders.
Anyway, the request is to show the expando-icon for any folders that have subs, like the normal treeview, without having to expand them first. It's not immediately obvious which favorites even have subfolders.
XnView 1.90 <x>
Yet another favorites issue - showing subfolders
foxyshadis
robc
Re: Yet another favorites issue - showing subfolders
I'm not sure it will be good to check for all favorites for subfolders...foxyshadis wrote:Today seems to be the day for them, eh? (I just found out xnview even has favorites.) It seems to really center around the idea of a folder being self-contained, no subfolders.
GeorgD
From a UI point of view: Favourites are a shortcut to often used folders, which are folders, hence they shall behave like folders. Consequently, they shall show whether they contain subfolders. At least I consider it to be a bug when i know "fav a contains subfolders" but I get no indication.xnview wrote:I'm not sure it will be good to check for all favorites for subfolders...
From a performance point of view: First listing the favourites themselves. When they're done, scan their content in two concurrent threads: one reads the files and shows thumbnails of the currently selected fav. The other crawls all favs for direct subfolders (file mask: +d, so the OS only returns dirs and ignores files), so breadth first, and adds the corresponding icon (+ or not) in front of the folder name. This means the user can use the current dir instantly but gets the information after a few secs.
Other thoughts? /Georg
robc
The way Favorites work in B3 looks good to me; the issue with hidden folders I pointed out above is still there, though, which is a pity.
On another note: is it possible to have XnView start with the tree pane on Favourites instead of Folders? if it's not, then I believe it would be a nice option to add.
marsh
robc
Danny
Me neither. I can't see how it matters anyway. The scanning needed is just useless work for the PC IMHO.xnview wrote:I'm not sure it will be good to check for all favorites for subfolders...foxyshadis wrote:Today seems to be the day for them, eh? (I just found out xnview even has favorites.) It seems to really center around the idea of a folder being self-contained, no subfolders.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
