• A nice small
1. In the Options, disable “Zoom High Quality ” for both “Enlarge” and “Reduce”
2. Display some small images in the Browser as thumb nails, i.e. small icons or so.
3. Get a preview for any one.
4. Zoom-in by 400% at least : now, you can see that the blown-up image is quite blurred,
that means the H. Q. zoom is still enabled.
5. Since there is not any separate setting, it's impossible to avoid this currently…:|
• No problem in “View”, it works properly.
