I would like to batch convert JPG files and crop them to a specific size with the cropped portion of the image coming from the center of the image. When I input Width and Height parameters, the image is cropped starting in the upper left corner.
For example, I want to batch crop all images to 800 x 600:
Original image is 600 x 1000: crop 100 from top and 100 from bottom
Original image is 600 x 1200: crop 200 from top and 200 from bottom
Original image is 1000 x 1000: crop 100 from left, 100 from right, 200 from top, and 200 from bottom
How do I set the Crop parameters to do this for a batch transformation?
Crop parameters for batch transformations
bamendt
Perhaps you can use canvas resize for that...bamendt wrote:My example had the wrong values. Corrected values are:
Original image is 600 x 1000: crop 200 from top and 200 from bottom
Original image is 600 x 1200: crop 300 from top and 300 from bottom
bamendt
