How to extract thumbnail image from files?
chomk
Post by chomk »
What is the difference between ExportToClipboard and SendBinary?
In Windows XP pro, I have to use .ExportToClipboard() method of GFLAX and then use clipboard image to show in VB.net Picture box control. In Win 2000, I can use .SendBinary() method. I cannot use SendBinary method in XP.
Please correct me if my code is wrong. I use VB.Net with VStudio 2005. My code works, but I don't it's a correct way to extract thumbnail from files. I can display images and PDF files with these code.
Dim objGFL as New GflAx.GflAx
With objGFL
.LoadBitmap(strFileName)
.SaveFormat = AX_JPEG
IF WinXP Then
Else
Dim objMS as MemoryStream = New MemoryStream( .SendBinary() )
End If
End With
And then I can use clipboard or memory stream to display image in Picture box control. I don't want to use two methods according to OS. Is there any other way to extract image from files (images or PDF)?
Thanks in advance
CMK
Re: How to extract thumbnail image from files?
chomk wrote:Hello,
ExportToClipboard is to export picture in widnows clipboard. SendBinary send picture on the stream
chomk
Post by chomk »
Thanks for your reply. I know it already. But I cannot use SendBinary function on my Windows XP (Pro - service pack 2). It causes exception - "Specified array was not of the expected type.". This function works well on Windows 2000 machine and I can load thumbnail image from returned stream.
Regards
chomk
Post by chomk »
Sorry, I need to add some more details.
That exception occurs when calling SendBinary function with TIF image. But I'm sure the same result with other supported file formats (eg. PDF).
Thanks
