Detachable menus
dcakovan
Detachable menus
Post by dcakovan »
It would be useful for image editing if menus could be detached. That way you do not have to keep digging through menus to repeat something or try-out something else... example, image>adjust submenu
Here is Maya detachable menus...
Thanks for all the work you guys put into this application.
-Djordje
XnView 1.90 <x>
Re: Detachable menus
dcakovan wrote:It would be useful for image editing if menus could be detached. That way you do not have to keep digging through menus to repeat something or try-out something else... example, image>adjust submenu
-Djordje
Yes Menu in Maya are great, but currently i can't add this feature
dcakovan
Post by dcakovan »
Not a problem. I just thought I give it a try.
Olivier_G
Post by Olivier_G »
-> moved to 'Postponed'
Olivier
